True View Panel
Use the True View panel to change the current view of your model based on a model vector or angles.
Panel Options
Option Action
thetax Specify the rotation about the x axis
thetay Specify the rotation about the y axis
thetaz Specify the rotation about the z axis
N1, N2, N3, B Select the plane whose normal should be oriented normal to the screen.
Command Buttons
Button Action
set angles Set the view angles to the values entered in the fields.
get angles Place the current view angles in the corresponding fields.
true view Display the true view.
