HM_ExtAPI::ComponentFindByImportedName()
Finds a component by its original name.
bool ComponentFindByImportedName(
const char* name,
HM_EntityComponent& comp
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode(). The handle comp in this case returns NULL entity.
Requires including hm_extapi.h.
- name
 - [in] - Pointer to the string that contains the name.
 - comp
 - [out] - Returns the handle to component object in case the component with imported name exists.
None.
