HM_ExtAPI::GeomFaceGetComponent()
Returns component that contains the face.
bool GeomFaceGetComponent(
const HM_EntityGeomFace & face,
HM_EntityComponent& comp
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
face
[in] - Handle to face object that was returned by previous calls to API function.
comp
[in] - The handle to the component. The value of the handle is NULL if the face handle is invalid.
None.
