HM_ExtAPI::GeomFaceGetLoopsCount()
Returns number of loops in the face.
bool GeomFaceGetLoopsCount(
const HM_EntityGeomFace & face,
int& loops_count
HyperMesh Ext API Function
Each face has at least one loop that defines its external boundary in parametric space.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- face
 - [in] - Handle to face object that was returned by previous calls to API function.
 - loops_count
 - [out] - Number of loops.
None.
