HM_ExtAPI::GetInternalModelTolerance()
Returns equivalence tolerance value for the model.
double GetInternalModelTolerance();
HyperMesh Ext API Function
The function can be used to obtain internal tolerance value used for model cleanup and equivalencing operations.
The function returns current tolerance value.
Requires including hm_extapi.h.
None.
