HM_ExtAPI::ReleaseGeomSurface()
Releases the handle to temporary surface.
bool ReleaseGeomSurface(
const HM_EntityGeometrySurface& surface
HyperMesh Ext API Function
The function ReleaseGeomSurface must be used to release the handle to temporarily created during the call to some of API functions surface object.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
surface
[in] - Handle to surface object that was returned by previous calls to API functions.
None.
