HM_ExtAPI::SetInternalModelTolerance()
Sets equivalence tolerance value for the model.
bool SetInternalModelTolerance(
double tol,
HyperMesh Ext API Function
The function provides control to internal tolerance value used for model cleanup and equivalencing operations.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
tol
[in] - Tolerance value. Must be positive.
None.
