HM_ExtAPI::GeomFacesConnectByEdgeEquivalencing()
Connects faces by equivalencing their edges.
bool GeomFacesConnectByEdgeEquivalencing(
const HM_EntityComponent& comp,
int num_faces,
const HM_EntityGeomFace* faces,
double equiv_tol
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- comp
 - [in] - If not NULL then all faces of the component specified by this parameter are selected for equivalencing operation. Ignored if parameter faces is not NULL.
 - num_faces
 - [in] - If not zero then number of faces selected for equivalencing operation.
 - faces
 - [in] - If not NULL then points to array of faces selected for equivalencing operation. The number of entities in the array must be num_faces.
 - equiv_tol
 - [in] - Specifies equivalence tolerance. If the number is negative or zero then equivalence tolerance is set automatically.
None.
