HM_ExtAPI::MeshGetGridCount()
Returns total number of mesh grid points in a mesh object.
bool MeshGetGridCount(
const HM_EntityMesh& hmesh,
int& grid_count
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
hmesh
[in] - Handle to mesh object that was returned by previous calls to API functions.
grid_count
[out] - Total number of grid points in the mesh referenced by mesh object.
None.
