HM_ExtAPI::GeomVertexGetGeometry()
Returns vertex geometry.
bool GeomVertexGetGeometry(
const HM_EntityGeomVertex & vertex,
HM_Point & vertex_point
HyperWorks Tcl Query Command
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- vertex
 - [in] - Handle to vertex object that was returned by previous calls to API functions.
 - vertex_point
 - [out] - The structure HM_Point that contains vertex coordinates when the function returns.
None.
