HM_ExtAPI::GridGetPosition()
Returns position of the grid point of a mesh.
bool GridGetPosition(
const HM_EntityMesh & hmesh,
const HM_EntityGrid & hgrid,
HM_Point & point
HyperMesh Ext API Function
The grid point referenced by the handle hgrid must belong to the mesh referenced by the handle hmesh. That is only the grid handles obtained in previous calls to API functions using the same mesh handle hmesh must be used.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
hmesh
[in] - Handle to mesh object that was returned by previous calls to API functions.
hgrid
[in] - Handle referencing the grid point.
point
[in] - The structure HM_Point that contains grid point coordinates when the function returns.
None.
