HM_ExtAPI::CreateSurfaceCylinder()
Creates cylindrical surface object.
bool CreateSurfaceCylinder(
HM_EntityGeometrySurface& new_cylinder,
const HM_Point& center_point,
const HM_Vector& axis,
const HM_Vector& origin_dir,
double radius,
double axis_vfactor
HyperMesh Tcl Modify Command
The function creates the surface object of the type HM_ExtAPI::CYLINDER().
The points on the surface of the cylinder can be calculated parametrically as
S(U, V) = C + R ( p cos U + [n X p] sin U ) + ε n V,
p = P - n (nP) , n = N / | N |
| Parameters used by CreateSurfaceCylinder | Cylinder parameters |
| center_point | C |
| axis | N |
| origina_dir | P |
| radius | R |
| axis_vfactor | ε |
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- new_cylinder
 - [out] - Handle to new surface object.
 - center_point
 - [in] - Center point of the circular cross section at cylinder base.
 - axis
 - [in] - Cylinder axis vector.
 - origin_dir
 - [in] - Vector that defines position of the circle corresponding to U=0 parameter.
 - radius
 - [in] - Cylinder radius.
 - axis_vfactor
 - [in] - The factor that defines the rate of the change of the cylinder height corresponding to the changes of V parameter (see Description section above).
None.
