HM_ExtAPI::GeomSurfaceGetPoint()
Returns surface point.
bool GeomSurfaceGetPoint(
const HM_EntityGeometrySurface & surf,
double u_param,
double v_param,
HM_Point& point
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
surf
[in] - Handle to surface object that was returned by previous calls to API functions.
u_param
[in] - U value of surface parameter.
v_param
[in] - V value of surface parameter.
point
[out] - Surface point corresponding to the surface parameter given by u_param and v_param values.
None.
