The standard block set includes over 100 engineering, scientific, and mathematical blocks that allow you to realize dynamic systems of any level of complexity.
See Also:
Accessing standard blocks
-X
less than (<)
less than or equal to (<=)
greater than (>)
greater than or equal to (>=)
1/X
abs
acos
ActiveX read
ActiveX write
and
animate
animation3D
asin
atan2
audioIn
audioOut
bessel
beta
bezel
buffer
button
camera3D
case
cauchy
comment
complexToReIm
const
constraint
convert
cos
cosh
cost
crossDetect
csd
date
DDE
DDEreceive
DDEsend
deadband
delayedSwitch
demux
derivative
diag
dialogConstant
dialogTable
display
dotProduct
eigenvalues
embed
erlang
error
eventDisplay
eventLog
execOrder
exp
export
expression
fft
flip
FMU Import
gain
gamma
gaussian
globalConstraint
histogram
ifft
import
index
indexedAssign
int
invert
integrator
Kafka Consumer
Kafka Producer
Knowledge Studio Scoring
label
light
light3D
limit
limitedIntegrator
linearSolve
lineDraw
ln
log10
magPhase
map
matrixConst
matrixIn
matrixMerge
matrixOut
matrixSize
max
maxElement
meanSmooth
medianSmooth
merge
mesh3D
meter
min
minElement
mldivide
multiply
not
OLEobject
or
parabola
parameterUnknown
pareto
plot
plot3D
PolarPlot
polyFit
polyRoots
pow
PRBS
psd
PSIM Connector
pulseTrain
quantize
ramp
rayleigh
realTime
relay
resetIntegrator
reshape
sampleHold
sawtooth
scalarToStruct
scalarToVec
section
sign
sin
sinh
sinusoid
slider
spectrumDisplay
splineFit
sqrt
squareWave
stateSpace
stateTransition
step
stop
stripChart
structToScalar
summingJunction
tan
tanh
timeDelay
timeOfDay
timeStamp
transferFunction
transpose
triangleWave
triangular
uniform
unitConversion
unitDelay
unknown
userFunction
variable
vectorSort
vecToScalar
video
vsum
weibull
wirePositioner
world3D
xor
