*alefsiprojections()
Starts an alefsiprojections block.
*alefsiprojections (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
- config
 - An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all alefsiprojections with the format:
*alefsiprojections(id,"name")
  *format()
    *string("*alefsiprojections(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
    Version History
2019
