*sortsets()
Sets the order that sets are output in a *sets() block.
*sortsets (order)
HyperMesh Template Command
order
Valid values are:
byid - Ordering is performed by ID.
none - No ordering is performed.
To output elements in order based on ID:
*sets()
  *sortsets(byid)
  *format()
    *string("id = ")
    *field(integer,id,0)
    *end()
*output()
Version History
14.0
