*parameters()
Starts a parameters block.
*parameters (card_image_name)
HyperMesh Template Command
This command must be accompanied by an *output() command at the end of the block
- card_image_name
 - A 32-character string enclosed in double quotes that defines the card image name of the parameter. If specified as double quotes "", all parameters are considered for the block.
To write out all parameters with the format:
*parameters(id,"name")
*parameters("")
  *format()
    *string("*parameters(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
    Version History
14.0
