*materials()
Starts a material block.
*materials (card_image_name)
HyperMesh Template Command
Starts a material block. Materials with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
- card_image_name
 - A 32-character string enclosed in double quotes that defines the card image name of the materials in the block. If specified as double quotes "", all materials are considered for the block.
To write out all materials with the format:
*material(id,"name",color)
*materials("","")
*format()
*string("*material(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,color,0)
*string(")")
   *end()
*output()
