*writegeometry()
Outputs the Altair geometry database in an internal ASCII format.
*writegeometry (string)
HyperMesh Template Command
string
A small string to be inserted at the beginning of each line to serve as a comment character.
This format is designed to be read in with the hminlib function HM_writegeomdata().
