*plies()
Starts a ply block.
*plies (card_image_name)
HyperMesh Template Command
Starts a ply block. Plies with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
- card_image_name
 - A 32-character string enclosed in double quotes that defines the card image name of the plies. If specified as double quotes "", all plies are considered for the block.
To write out all plies with the format:
*ply(id,"name",color)
*plies("")
*format()
*string("*ply(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,color,0)
*string(")")
   *end()
*output()
    Version History
11.0
