*sortloadsteps()
Changes the order that loadsteps are output in a *loadsteps() block.
*sortloadsteps (sort type)
HyperMesh Template Command
- sort type
byid sort loadsteps by ID none sorting is not performed
The following example outputs all loadsteps by ID:
*loadsteps(1,0,"")
  *before()
    *sortloadsteps(byid)
  *format()
    *string("Loadstep ID")
    *field(real,id,0)
    *end()
*output()
