*sketches()
Starts a sketch output block. All the sketches are output according to the user-defined format in this block.
*sketches ()
HyperMesh Template Command
Starts a sketch block.
Requires an *output() command at the end of the output block definition.
To write out all sketches with the format:
*sketches(id,"name")
*sketches()
  *format()
    *string("*sketches(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Incorrect usage results in an import error.
Version History
2021.2
