*properties()
Starts a property block.
*properties (card_image_name, mat_card_image_name,?idpool_name?)
HyperMesh Template Command
Starts a property block. Properties with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
- card_image_name
 - A 32-character string enclosed in double quotes that defines the card image name of the property. If specified as double quotes "", all properties are considered for the block.
 - mat_card_image_name
 - A 32-character string enclosed in double quotes that defines the name of the material that the properties in the block require. If not needed, use double quotes "".
 - idpool_name
 - An optional 32-character string enclosed in double quotes that defines the name of the ID pool that the properties belongs to. If not needed, use double quotes "" or omit the argument.
To write out all properties with the format:
*property(id,"name",material ID,color)
*properties("","")
*format()
*string("*property(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,materialid,0)
*string(",")
*field(integer,color,0)
*string(")")
   *end()
*output()
