*tables()
Starts a tables block.
*tables (card_image_name, ?idpool_name?)
HyperMesh Template Command
Starts a tables block. Tables with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
card_image_name
A 32-character string enclosed in double quotes that defines the card image name of the table. If specified as double quotes "", all tables are considered for the block.
idpool_name
An optional 32-character string enclosed in double quotes that defines the name of the ID pool that the table belongs to. If not needed, use double quotes "" or omit the argument.
The ID pool must be defined using the *defineidpool() command.
To write out all tables with the format:
*table(id,"name",rows,columns)
*tables("","")
*format()
*string("*table(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,rows,0)
*string(",")
*field(integer,columns,0)
*string(")")
*end()
*output()
Version History
11.0
