*executetclscript()
Executes a Tcl script from within a template, and optionally calls a procedure defined in the script.
*executetclscript (filename, proc_name)
HyperMesh Template Command
This command should be called in the *before() section.
- filename
 - Full path of the Tcl file to be executed. The path should be always defined with two back slashes.
 - proc_name
 - Name of the procedure to be executed. If not required, use two empty quotes.
C:\TclScripts\test.tcl"
        without a call to specific procedure:*executetclscript("C:\\TclScripts\\test.tcl","")
      C:\TclScripts\test.tcland
        call a procedure named TestProc:*executetclscript("C:\\TclScripts\\test.tcl","TestProc")
