*beamsectcols()
Starts a beamsectcols block.
*beamsectcols ()
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
To write out all beamsectcols with the format:
*beamsectcols(id,"name",color)
*beamsectcols()
*format()
*string("*beamsectcols(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,color,0)
*string(")")
*end()
*output()
