*solversettings()
Starts a solversettings block.
*solversettings (config)
HyperMesh Template Command
Requires an *output() command at the end of the output block definition.
config
An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all solversettings with the format:
*solversettings(id,"name")
*solversettings()
  *format()
    *string("*solversettings(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Incorrect usage results in an import error.
Version History
2021.2
