*cards()
Starts a Control Card output block.
*cards (card name)
HyperMesh Template Command
card name
The name of the card to output.
To output the CTRL_TITLE card the following commands may be used:
*cards("CTRL_TITLE")
 *format()
  *string("TITLE / ")
  *string(" ")
  *fieldleft(string,$TITLE_VAL,48)
*end()
*output()
Requires a *output() at the end of the block.
