*loadcols()
Starts a load collector block.
*loadcols (card_image_name, ?idpool_name?)
HyperMesh Template Command
Starts a load collector block. Load collectors with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
- card_image_name
 - A 32-character string enclosed in double quotes that defines the card image name of the load collector. If specified as double quotes "", all load collectors are considered for the block.
 - idpool_name
 - An optional 32-character string enclosed in double quotes that defines the name of the ID pool that the load collectors belongs to. If not needed, use double quotes "" or omit the argument.
To write out all load collectors with the format:
*loadcollector(id,"name",color)
*loadcols("","")
*format()
*string("*loadcollector(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,color,0)
*string(")")
   *end()
*output()
