CDAMP4
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points and is without reference to a material or property entry.
CDAMP4 EID B S1 S2
CDAMP4 16 -2.6 4 9
EID Unique element identification number.
No default (Integer > 0)
B Scalar damper value.
No default (Real)
S1, S2 Scalar point identification numbers.
Default = 0 (Integer ≥ 0; S1 ≠ S2)
  1. S1 or S2, but not both, may be blank or zero, indicating a constrained coordinate.
  2. This single entry completely defines the element since no material or geometric properties are required.
  3. Only one scalar damper element may be defined on a single entry.
  4. A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
  5. Scalar damper elements are ignored in heat transfer analysis.
  6. This card is represented as a spring or mass element in HyperMesh.
