PCONTEC
Bulk Data Entry Defines Contact Electric Coefficient (CEC) for CONTACT elements in electrical analysis.
PCONTEC | PID | KCERC |
Examples
PCONTEC | 2 | 200.0 |
PCONTEC | 2 | AUTO |
- PCONTEC provides resistance per
unit area for CONTACT elements. The
PID of a PCONTEC Bulk Data Entry must
match that of an existing PCONT Bulk Data Entry.
If the secondary side is specified as grid set, then you can assume that a unit area is assigned to each grid in this set.
Resistance per unit area is in the same unit as electric coefficients, also called contact ER (electrical resistance). Total conductance is calculated as contact area divided by KCERC.
- KCERC represents contact
electrical resistance values for closed contacts. Theoretically, while lower
contact electric resistance values enforce a perfect conductor, excessively low
values may cause poor conditioning of the conductance matrix. If such symptoms
are observed, you may need to increase the value of contact electrical
resistance.
To facilitate reasonable values for KCERC, automatic calculation (KCERC=AUTO) is supported. This determines the value of KCERC for each contact element using the contact electric conductance values of surrounding elements.
- PCONTEC is not supported for surface-to-surface contact (DISCRET=S2S on CONTACT/TIE).
- For CONTACT interfaces without PCONT, PCONTEC is not required. Contact Electrical Resistance values based on KCERC=AUTO is utilized in such cases.
- Electrical contact with FREEZE status uses the actual contact status (open or closed) based on geometry.
- Electrical Contact Analysis via PCONTEC and PGAPEC is supported for Steady-State Electric Analysis and Multi-Steady Electric Analysis.
- This card is represented as a property in HyperMesh.
