MATT2PT
Bulk Data Entry Defines temperature-dependent anisotropic permittivity via the TABLEM1-4 or TABLEG Bulk Data Entries for dielectric materials.
MATT2PT | MID | T( ) | T( ) | T( ) | T(DAMP) |
MATT2PT | 1 | 1001 | 1002 | 1003 | 1004 |
MID | Material property
identification number. Must match the identification number on MAT2PT Bulk Data Entry. No default (Integer > 0) |
T( ) | Identification number of
the TABLEM1-4 or TABLEG Bulk Data Entries defining the
temperature-dependent piezoelectric permittivity along the X
direction. Default = blank (Integer > 0) |
Data Entries defining the temperature-dependent piezoelectric
permittivity along the Y direction. Default = blank (Integer > 0) |
permittivity along the Z direction. Default = blank (Integer > 0) |
T(DAMP) | Identification number of
Data Entries defining term corresponding to the static electrical
part. Default = blank (Integer > 0) |
- The quantities defined on the MAT2PT Bulk Data Entry are multiplied by the tabular function referenced in the MATT2PT Bulk Data Entry to generate the corresponding material data.
- If the fields are blank or zero, then constant properties defined on the MAT2PT Bulk Data Entry are used.
- For more information, refer to Piezoelectric Analysis in the User Guide.
