PRETPRM
Bulk Data Entry Defines parameters that control initial loading conditions on pretension sections for 1D and 3D bolt pre-tensioning. These parameters also control the printing of diagnostic information about pretension sections.
PRETPRM PARAM1 VAL1 PARAM2 VAL2 etc.
PRETPRM INILOAD ZEROF PRTSW YES
PARM# Name of the parameter
VAL# Value of the parameter
Supported Parameters
