MAT8
Bulk Data Entry Defines the material properties for linear temperature-independent orthotropic material for two-dimensional elements.
| MAT8 | MID | E1 | E2 | NU12 | G12 | G1,Z | G2,Z | RHO | |
| A1 | A2 | TREF | Xt | Xc | Yt | Yc | S | ||
| GE | F12 | STRN | |||||||
| RAYL | ALPHA | BETA |
| MAT8 | 171 | 30.+6 | 1.+6 | 0.3 | 2.+6 | 3.+6 | 1.5+6 | 0.056 | |
| 28.-6 | 1.5-6 | 155.0 |
| MID | Unique material identification.
No default (Integer > 0 or <String>) |
| E1 | Modulus of elasticity in longitudinal direction (also defined as fibre direction or
1-direction) 7 No default (Real ≠ 0.0) |
| E2 | Modulus of elasticity in lateral direction (also defined as matrix direction or
2-direction) 7 No default (Real ≠' 0.0) |
| NU12 | Poisson's ratio (
for uniaxial loading in 1-direction). Note that
for uniaxial loading in 2-direction is related to
12, E1, E2 by the relation
12
E2 =
21
E1. No default (Real) |
| G12 | Inplane shear modulus. No default (Real > 0.0) |
| G1,Z | Transverse shear modulus for shear in 1-Z
plane. Default = blank (Real > 0.0 or blank) |
| G2,Z | Transverse shear modulus for shear in 2-Z
| RHO | Mass
density. No default (Real) |
| A1 | Thermal expansion coefficient in
1-direction. No default (Real) |
| A2 | Thermal expansion coefficient in
2-direction. No default (Real) |
| TREF | Reference temperature for the calculation of thermal loads. 3. Default = blank (Real or blank) |
| Xt, Xc, Yt, Yc | Allowable stresses or strains in the longitudinal
and lateral directions. Used for composite ply
failure calculations. No default (Real > 0.0) |
| S | Allowable for in-plane shear stresses or strains
for composite ply failure calculations. No default (Real > 0.0) |
| GE | Structural Element Damping
Coefficient. TREF and GE are ignored, if a MAT8 entry is referenced by a PCOMP entry. No default (Real) |
| F12 | Tsai-Wu interaction term for composite failure. Default = 0.0 (Real) |
| STRN | Indicates whether Xt,
Xc, Yt,
Yc, and S
are stress or strain allowables. Default = blank (Real = 1.0 for strain allowables, blank for stress allowables) |
| RAYL | Continuation line flag for material-dependent Rayleigh damping. | |
| ALPHA | Material-dependent Rayleigh Damping
coefficient for the mass matrix. Default = blank (Real ≥ 0.0) |
| BETA | Material-dependent Rayleigh Damping
coefficient for the stiffness matrix. Default = blank (Real ≥ 0.0) |
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
- String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- If G1,Z and G2,Z values are specified as zero or are not supplied, a penalty term is used to enforce very high transverse shear stiffness.
- An approximate value for G1,Z and G2,Z is the inplane shear modulus G12. If test data is not available to accurately determine G1,Z and G2,Z for the material and transverse shear calculations, the value of G12 may be supplied for G1,Z and G2,Z.
- Long field format can be used.
- The
option of interpreting Xt, Xc,
Yt, Yc, and S as strains is only
available for composite definitions (PCOMP or PCOMPG) using the Maximum Strain (STRN) failure
criterion. In this case, the STRN flag indicates whether
Xt, Xc, Yt,
Yc, and S are stress or strain allowables. For the
STRN failure criterion, if the STRN field on
MAT8 is set to "blank", the strain allowables are calculated from the
corresponding stress allowables.
For all other failure criteria Xt, Xc, Yt, Yc, and S are always interpreted as stresses, regardless of the value of the STRN flag.
- The value of E1 should be greater than that of E2 for the material to be stable. If E1 < E2, the material matrix becomes indefinite leading to an unstable material.
- For material-dependent Rayleigh damping, the equivalent viscous damping,
, is defined as:
(1) Where,- ALPHA and BETA
- Defined on the RAYL continuation line on the material entry
- Mass matrix
- Stiffness matrix
- Direct Frequency Response
- Modal Frequency Response
- Direct Transient Response
- Modal Transient Response
- Nonlinear Transient Analysis
- Explicit Dynamic Analysis
- This card is represented as a material in HyperMesh.
