MONVOL
Bulk Data Entry Defines a one-chamber gas filled structure with hybrid input of inflated gas.
| MONVOL | MID | UNIT | |||||||
| SURF | SID | ||||||||
| AMBIENT | PATM | TATM |
| IAIR | PAIR | TAIR | |||||||
| XMAIR | Cpa_air | Cpb_air | Cpc_air | Cpd_air | Cpe_air |
| + | VENT | SIDV | C23 | LCTC23 | LCPC23 | PDEF |
| + | MATGAS | LCM | LCT | ||||||
| XM |
| MONVOL | 1 | ||||||||
| SURF | 10 | ||||||||
| AMBIENT | 1.013E5 | 293.0 | |||||||
| MATGAS | 3 | 4 | |||||||
| 0.004 | 40.0 | 0.0 | 0.0 | ||||||
| IAIR | 1.013E5 | 293.0 | |||||||
| 0.028 | 28.0 | 0.0 | 0.0 |
| MID | Monitor volume identification number. No default (Integer > 0) |
| UNIT | Unit system.
| SURF | Flag to indicate the external surface of enclosed volume. | |
| SID | External surface identification defined by a set of
elements. No default (Integer > 0) |
| ATM | Flag to indicate that the two following fields define atmospheric pressure and temperature. | |
| TATM | Ambient temperature. Default=293 K (Real ≥ 0.0) |
| PATM | Ambient pressure. Default=1 atm (Real ≥ 0.0) |
| VENT | Flag to indicate that the following five fields indicate the vent hole properties. | |
| SIDV | Vent hole area surface identification number. No default (Integer > 0) |
| C23 | Scale factor on vent hole area. Default=1.0 (Real > 0.0) |
| LCTC23 | Curve defining vent hole coefficient as a function of
time. No default (Integer > 0) |
| LCPC23 | Curve defining vent hole coefficient as a function of
pressure. No default (Integer > 0) |
| PDEF | Pressure difference between interior and ambient pressure to
open vent hole. Default=0.0 |
| MATGAS | Flag to indicate that the following four fields define the inflated gas properties. | |
| LCM | Table that defines mass flow rate curve for the gas component. | |
| LCT | Table that defines temperature curve for the gas component. | |
| XM | Molar mass of the gas component. | |
| Cpa, Cpb, Cpc, Cpd, Cpe | Molar heat capacity coefficients of the inflow gas at constant pressure. 4 | |
| IAIR | Flag to indicate that the following four fields define properties of the initial gas inside the structure. | |
| PAIR | Initial pressure inside
structure. Default=PATM (Real ≥ 0.0) |
| TAIR | Initial temperature inside
structure. Default=TATM (Real ≥ 0.0) |
| XMAIR | Molar mass of air initially inside structure. No default (Real ≥ 0.0) |
| Cpa_air, Cpb_air, Cpc_air, Cpd_air, Cpe_air | Molar heat capacity coefficients of the initial air at
constant pressure. 4 No default (Real ≥ 0.0) |
- The volume must be a completely enclosed volume and the norm must be oriented outwards. If the structure contains a vent hole, the vent hole must be meshed with a shell element.
- The value of the total vent hole
coefficient must be between 0.0 and 1.0:
(1) Total vent hole coefficient = min(max(C23 × LCTC23 × LCPC23, 0.0), 1.0).
- There is no limit on the number of gas components.
- Heat capacity at constant
pressure:
(2) Where, is temperature.
- Support information for
MONVOL:
- Supported Analysis Types
- Explicit Dynamic Analysis
