Bulk Data Entry Defines a pretension load as a linear combination of
load sets defined via PTFORCE, PTFORC1,
PTADJST and PTADJS1 entries.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| PTADD |
PSID |
S |
S1 |
L1 |
S2 |
L2 |
S3 |
L3 |
S4 |
L4 |
etc. |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| PTADD |
6 |
2.0 |
3.0 |
2 |
2.0 |
3 |
| Field |
Contents |
SI Unit Example |
| PSID |
Pretensioning load set
identification number. |
| S |
Scale factor. 1 No default (Real)
| Si |
| Li |
Pretension load set
identification number defined via entry types enumerated above.
1 No default (Integer >
0)
- The pretension load as a linear combination is defined
by:(1)
