SENSOR
Bulk Data Entry Defines different types of sensors. Sensors may be used to activate loads.
| SENSOR | SID | STYPE | DELAY | NACC |
| LSID | GID | LBOUND/LTID | UBOUND/UTID |
| AID1 | DIR1 | AMIN1 | TMIN1 | ||||||
| AID2 | DIR2 | AMIN2 | TMIN2 | ||||||
| etc. | etc. |
| G1 | G2 | DMIN | DMAX |
| SID1 | SID2 |
| SID1 |
| CID |
| RWID |
Example 1
| SENSOR | 100 | ACCEL | 1 | ||||||
| 7 | X | 500.0 | 0.03 |
Example 2
| SENSOR | 2 | TEMP | |||||||
| 4 | 933 | 100.0 | 200.0 |
| SID | Unique sensor
| STYPE | Sensor type. May be one
of:
No default |
| LSID | Load set identification
number of a QBDY1 or QVOL Bulk Data Entry. No default (Integer > 0) |
| GID | Grid or scalar point
| LBOUND/LTID | Lower bound of the
temperature range, or the table identification number of a
TABLEDi entry which specifies the lower bound
as a function of time. No default (Real or Integer) |
| UBOUND/UTID | Upper bound of the
TABLEDi entry which specifies the upper bound
| DELAY | Time delay. (Real > 0) |
| NACC | Number of accelerometers
ACCEL. (0 < Integer ≤ 6) |
| AID# | Accelerometer
identifier References the ID of an ACCLR Bulk Data Entry. (Integer > 0) |
| DIR# | Direction of accelerometer
#. May be one of:
No default |
| AMIN# | Minimum absolute value for
acceleration for accelerometer #. (Real ≥ 0) |
| TMIN# | Minimum duration of
AMIN for accelerometer #. (Real ≥ 0) |
| G1 | Grid ID 1. (Integer > 0) |
| G2 | Grid ID 2. (Integer > 0) |
| DMIN | Distance minimum. (Real ≥ 0) |
| DMAX | Distance maximum. (Real ≥ 0) |
| SID1 | Activation sensor
identifier. References the ID of another SENSOR Bulk Data Entry. (Integer > 0) |
| SID2 | Deactivation sensor
| CID | Contact
identifier. References the ID of a CONTACT Bulk Data Entry. (Integer > 0) |
- For
STYPE=ACCE, the sensor is activated if one
of the accelerometers gives an acceleration greater than AMIN
during a time greater than TMIN.
The time of activation of the sensor is the time at which the above criteria is first met plus the time delay (DELAY).
- For STYPE=DIST, the sensor is activated
once the distance between G1 and G2 moves
outside the allowable range (between DMIN and
DMAX).
The time of activation of the sensor is the time at which the above criteria is first met, plus the time delay (DELAY).
- For STYPE=SENS, the sensor is activated
once the referenced sensor SID1 is activated. The minimum
activation duration is given by the time delay (DELAY). After
this minimum activation duration, the sensor is deactivated if referenced sensor
SID2 is activated. If there is no SID2
referenced, then the sensor is deactivated after the time delay.
Figure 1. - For
STYPE=AND, the sensor is activated once both
the referenced sensors (SID1 and SID2) are
activated.
Figure 2. - For
STYPE=OR, the sensor is activated once
either of the referenced sensors (SID1 or
SID2) are activated.
Figure 3. - For
STYPE=NOT, the sensor is active whenever the
referenced sensor SID1 is not active.
Figure 4. - For
STYPE=INTER, the sensor is activated once
the referenced contact (CID) is impacted. The sensor is
deactivated if there is no impact during a time equal to the time delay
(DELAY).
Figure 5. - For
STYPE=RWAL, the sensor is activated once the
referenced rigid wall (RWID) is impacted. The sensor is
(DELAY).
Figure 6. - The presence of the SENSOR Bulk Data Entry with TYPE=TEMP turns off the referenced LSID loading outside the defined temperature range and turns on the LSID loading inside the temperature range (LBOUND/LTID to UBOUND/UTID).
