TSTEPE
Bulk Data Entry Defines time step parameters for control and intervals at which a solution will be generated and output in explicit analysis.
| TSTEPE | SID | TYPE | DTFAC | DTMIN | DTMAX |
| TSTEPE | 2 | ELEM | .9 | 1.0-7 | 1.0.-2 |
| SID | Set identification
number. No default (Integer > 0) |
| TYPE | Explicit time step control
types. 2
| DFAC | Scale factor for stable
time increments. OptiStruct will scale
the global stable time increment computed based on the time step
control type chosen in TYPE field. Default = 0.9 (Real > 0.0) |
| DTMIN | Minimum allowed time
increment. This option is only supported for
TYPE=NODA. If the number is
larger than the computed critical time increment
(DTFAC times the global stable time
increment), mass scaling will be used. In case mass scaling is activated, the new minimum time increment is DTMIN. For mass scaling, mass is added every time the critical time increment is less than DTMIN. 3 Default = 0.0 (Real ≥ 0.0) |
| DTMAX | Maximum allowed time
increment. No default (Real > 0.0) |
- TSTEPE entries must be selected by the Subcase Information command TSTEPE= SID.
- When calculating nodal time step, nodal stiffness includes contribution from contact nodes. Increasing contact penalty could decrease time increment and increase number of cycles.
- Mass scaling is only applied to nodes for which the scaled critical time step (scaled by DTFAC) falls below DTMIN.
