PBEAM
Bulk Data Entry Defines the properties of beam elements defined via the CBEAM entry.
PBEAM | PID | MID | A(A) | I1(A) | I2(A) | I12(A) | J(A) | NSM(A) | |
C1(A) | C2(A) | D1(A) | D2(A) | E1(A) | E2(A) | F1(A) | F2(A) |
SO | X/XB | A | I1 | I2 | I12 | J | NSM | ||
C1 | C2 | D1 | D2 | E1 | E2 | F1 | F2 |
K1 | K2 | NSIA | NSIB | ||||||
M1A | M2A | M1B | M2B | N1A | N2A | N1B | N2B |
Figure 1. Beam Element Coordinate System (for PBEAM)
Example 1
PBEAM | 9 | 7 | 9.5 | 18.073 | 98.792 | 0.813 | |||
0.0 | 2.0 | 0.0 | -2.0 | ||||||
NO | 1.0 | ||||||||
2.1 | |||||||||
0.5 |
Example 2
NO | 0.5 | 6.5 | 5.385 | 35.542 | 0.563 | ||||
YES | 1.0 | 3.5 | 0.698 | 7.292 | 0.313 | ||||
2.1 | |||||||||
0.5 |
PID | Unique simple beam
property identification.
No default (Integer > 0 or <String>) |
MID | Material identification.
1
2
A(A) | Area of beam cross-section
at end A. No default (Real > 0.0) |
I1(A) | Area moment inertia in
plane 1 about the neutral axis at end A. No default (Real > 0.0) |
I2(A) | Area moment inertia in
plane 2 about the neutral axis at end A. No default (Real > 0.0) |
I12(A) | Area product inertia at
end A (I1 * I2 > I122). Default = 0.0 (Real) |
J(A) | Torsional stiffness
parameter at end A. Default = 0.0 (Real ≥ 0.0) |
NSM(A) | Nonstructural mass per
unit length at end A. Default = 0.0 (Real) |
Ci(A), Di(A), Ei(A), Fi(A) | The y and z locations in
element coordinates for stress data recovery at end A. (i=1 is y and
i=2 is z). Default = 0.0 for all entries (Real) |
SO | Stress output request
option for intermediate stations and end B. 6
7
8
9
X/XB | Fractional distance of the
intermediate station from end A. Default = 1.0 (Real > 0.0) |
A | Area of beam cross-section
for intermediate stations. Default = A(A) (Real > 0.0) |
I1 | Area moment inertia in
plane 1 about the neutral axis for intermediate stations. Default = I1(A) (Real > 0.0) |
I2 | Area moment inertia in
plane 2 about the neutral axis for intermediate stations. Default = I2(A) (Real > 0.0) |
I12 | Area product inertia for
intermediate stations (I1 * I2 > I122). Default = I12(A) (Real) |
J | Torsional stiffness
parameter for intermediate stations. Default = J(A) (Real ≥ 0.0) |
NSM | Nonstructural mass per
unit length for intermediate stations. Default = NSM(A) (Real) |
Ci, Di, Ei, Fi | The y and z locations in
element coordinates for stress data recovery for intermediate
stations. (i=1 is y and i=2 is z). 6 through 9 Default = 0.0 for all entries. (Real) |
K1,K2 | Shear stiffness factor K
in K*A*G for plane 1 and plane 2. Default = 1.0 for both (Real) |
NSIA | Nonstructural mass moment
of inertia per unit length about nonstructural mass center of
gravity at end A. Default = 0.0 (Real) |
NSIB | Nonstructural mass moment
gravity at end B. Default = NSIA (Real) |
M1A, M2A | (y,z) coordinates of
center of gravity of nonstructural mass at end A. Default = 0.0, 0.0 (Real) |
M1B, M2B | (y,z) coordinates of
center of gravity of nonstructural mass at end B. Default = M1A, M2A (Real) |
N1A, N2A | (y,z) coordinates of
neutral axis at end A. Default = 0.0, 0.0 (Real) |
N1B, N2B | (y,z) coordinates of
neutral axis at end B. Default = N1A, N2A (Real) |
- For structural problems, MID may reference only a MAT1 material entry. For heat transfer problems, MID may reference only a MAT4 material entry.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input file.
- Blank fields for K1 and K2 are defaulted to 1.0. If a value of 0.0 is used for K1 and K2, the transverse shear flexibilities are set to 0.0.
- One value for X/XB must be 1.0.
- The moments of inertia are defined
as:
(1) - Stress recovery is only allowed at end A and end B. Stress recovery at intermediate stations is not supported.
- If no stress data at end A is to be recovered, but a stress recovery location is defined for end B, then the first continuation entry, which contains the fields C1(A) through F2(A), may be omitted.
- If the continuation line containing values C1 through F2 is entirely blank for end B, the stress recovery locations defined for end A are used. However, if any entry is defined on this line, then all blank entries will default to 0.0 and not the corresponding entry for end A.
- Stress recovery locations must be the same for end A and end B.
- OSDIAG, 166, 1 may be
input in the I/O Options section of the input deck to bypass error terminations
caused by PBEAM definitions which violate the rules outlined
in Comments 6 and 9. In such instances, the following occurs:
- Warning messages regarding the violations are echoed to the .out file.
- Stress is not recovered at intermediate stations.
- Recovery locations defined for end A are also used for end B.
- For tapered beams, a single prismatic beam is created with properties obtained by weighted averaging of all station properties.
- The cross-sectional properties have to be specified fully for end A. For end B, blank fields mean that the properties are the same as for end A. For intermediate stations, blank fields result in a linear interpolation between the property value at end A and end B being used.
- The NSM specified at
end A is the default value for NSM at end B. The default for
all other stations is a linear interpolation between end A and end B. So, for a
constant NSM over the length of the beam, only
NSM at end A is required.The mass of the element is calculated as:
(2) If the NSM value is different in different stations, it is averaged over all the stations and the average is used in the element calculation.
- This card is represented as a property in HyperMesh.
