PSHEAR
Bulk Data Entry Defines the properties of a shear panel.
PSHEAR | PID | MID | T | NSM | F1 | F2 |
PSHEAR | 21 | 2 | .001 |
PID | Unique shear property
identification number. (Integer > 0) |
MID | Material
identification number of a MAT1 entry. (Integer > 0) |
T | Thickness of shear
panel. (Real ≠ 0.0) |
NSM | Nonstructural mass per
unit area. (Real) |
F1 | Effectiveness factor
for extensional stiffness along edges 1-2 and 3-4. Default = 0.0 (Real ≥ 0.0) |
F2 | Effectiveness factor
for extensional stiffness along edges 2-3 and 1-4. Default = 0.0 (Real ≥ 0.0) |
- The effective extensional area is defined by means of
equivalent rods on the perimeter of the element. If F1 ≤
1.01, the areas of the rods on edges 1-2 and 3-4 are set equal
to:
(1) Where, PA is the panel surface area (half the vector cross product area of the diagonals) and L12 and L34 are the lengths of sides 1-2 and 3-4. Thus, if F1 = 1.0, the panel is fully effective for extension in the 1-2 direction. If F1 > 1.01, the areas of the rods on edges 1-2 and 3-4 are each set equal to (0.5 x F1 x T).
Figure 1. Extensional Area for Shear PanelThus, if F1 = 30, the effective width of skin contributed by the panel to the flanges on edges 1-2 and 3-4 is equal to 15T. The significance of F2 for edges 2-3 and 1-4 is similar.
- Poisson's ratio coupling for extensional effects is ignored.
- This card is represented as a property in HyperMesh.
