PSURF
Bulk Data Entry Defines properties of a contact surface.
PSURF | PID | EDGECRIT |
PID | Property
EDGECRIT |
Default = 45.0 (ALL, or 0.0 ≤ Real ≤ 180.0) |
- This property can be referenced on the CONTACT Bulk Data Entry.
- PSURF is only supported for Explicit Dynamic Analysis (NLEXPL).
