MCOHED
Bulk Data Entry Defines the material properties for damage-based cohesive material models.
MCOHED | MID | KI | KII | KIII | SFC | VED | RHO | MXDMG | |
DMGINIID | DMGEVOID | ||||||||
RAYL | ALPHA |
Example 1 (no damage, no Rayleigh damping)
MCOHED | 2 | 9000. | 3000. | 3000. | -1.0 | 1.0e-3 | 0.99 |
Example 2 (with damage, no Rayleigh damping)
MCOHED | 2 | 9000. | 3000. | 3000. | -1.0 | 1.0e-3 | 0.99 | ||
20 | 23 |
Example 3 (no damage, with Rayleigh damping)
MCOHED | 2 | 9000. | 3000. | 3000. | -1.0 | 1.0e-3 | 1.0e-5 | 0.99 | |
± | RAYL | 0.22 |
MID | Material
KX, KY, KZ | Elasticity modulus
corresponding to Mode I, II and III deformation, when the card
is used in cohesive elements. Penalty stiffness corresponding to Mode I, II and III deformation, when the card is used in cohesive contacts. 2 No default (Real) |
for cohesive elements for cohesive contacts |
SFC | Stiffening factor in compression.
Default = 1.0 |
VED | Factor for viscous
energy dissipation. 3 Default = 0.0 (Real > 0.0) |
RHO | Density (mass per
volume) Default = 0.0 (Real ≥ 0.0) |
MXDMG | Maximum damage index,
above which the cohesive element is excluded from
analysis. Default = 1.0 (Real ≥ 0.0) |
DMGINIID | Damage initiation
entry ID. 4 Default = blank (Integer > 0) |
DMGEVOID | Damage evolution entry
RAYL | Continuation line flag for material-dependent Rayleigh damping 5 | |
ALPHA | Material-dependent
Rayleigh Damping coefficient for the mass matrix 5 Default = blank (Real ≥ 0.0) |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED entries.
- In cohesive contacts, it is recommended to use KII = KIII.
- In some cases, snap-back phenomena could appear in numerical models with cohesive elements. VED can be used to stabilize the solution.
- Cohesive material with traction
only can be defined by leaving the DMGINIID and
DMGEVOID fields as blank. In this case, cohesive
material behavior is linear elastic in nature. This is only supported for
cohesive elements.
DMGINIID and DMGEVOID must be specified with cohesive contact.
- For material-dependent Rayleigh
damping, the equivalent viscous damping,
, is defined
as:
(1) Where,- Defined on the RAYL continuation line on the material entry
- Mass matrix
- Nonlinear Transient Analysis
- For additional information, refer to Cohesive Zone Modeling in the User Guide.
