DMGINI
Bulk Data Entry Defines the damage initiation criteria.
DMGINI | DMGINIID | CRI | FLAT | LODE | |||||
Y1 | X1_1 | X1_2 | X1_3 | ||||||
Y2 | X2_1 | X2_2 | X3_3 | ||||||
Y3 | X3_1 | X3_2 | X3_3 | ||||||
etc. | etc. | etc. | etc. |
Example 1
DMGINI | 20 | MAXS | |||||||
20.0 | 50.0 | 50.0 |
Example 2
DMGINI | 22 | QUADE | |||||||
2.0E-3 | 2.4E-3 | 2.4E-3 |
DMGINIID | Damage initiation
CRI | Damage initiation criteria.
No default (Real) |
LODE | Valid only for
CRI=DUCTILE. Flag to activate load parameter dependence for ductile damage initiation. Default = blank |
FLAT | Valid only for
CRI=DUCTILE. Specifies the handling method for y-values outside the specified range of x-values.
Y_#, X#_i, X#_j, X#_k | The maximum value of
strain or stress/traction depending on damage initiation
type. No default (Real > 0.0) |
for
MAXE/QUADE criteria for MAXS/QUADS criteria |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
- Analysis support information for
the criteria are:
Analysis Types Criterion Nonlinear Static Analysis, Nonlinear Transient Analysis MAXE, MAXS, QUADE, QUADS Explicit Dynamic Analysis DUCTILE - When the DUCTILE
damage initiation criterion is used, the parameters are used:
LODE flag Y_# X#_i X#_j X#_k Specified Plastic Strain at failure Stress triaxiality Lode parameter Strain rate Blank Plastic Strain at failure Stress triaxiality Strain rate - For additional information, refer to Cohesive Zone Modeling in the User Guide.
