PCOHE
Bulk Data Entry Defines the properties for cohesive elements.
PCOHE | PID | MID | INT | THICKNESS | SECANT | CORDM |
PCOHE | 1 | 2 |
PID | Unique cohesive element property
MID | Normal and shear behaviors of the
cohesive elements entry identification number. MID on PCOHE should refer to the MCOHE, MCOHED, or MAT1 Bulk Data Entries. No default (Integer > 0) |
INT | Integration scheme of the cohesive
elements.
(Integer) |
THICKNESS | Initial thickness of cohesive layer
(applicable to MCOHED entry only).
Default = 1.0 |
SECANT | Stiffness type.
(Integer) |
CORDM | Material coordinate system
identification number. 2
(Integer ≥ 0) |
- All cohesive element property entries should have unique identification numbers.
- The cohesive material coordinate system is defined as the element local coordinate system by default or a prescribed system (CORDM = Integer ≥ 0). The material local 3-direction is taken as the cohesive normal direction corresponding to Mode I fracture, and the material local 1- and 2-directions correspond to Mode II and III fracture.
