PACPML
Bulk Data Entry Defines the properties of acoustic Adaptive Perfectly Matched Layer (APML) elements.
PACPML | PID | MID | MODINT | ||||||
ESBYL | TBYL | MESHG | MESHM | DBNAME | |||||
EPS | XP | YP | ZP | ||||||
MFID | NBND | BNDTYP | ADAPF |
PACPML | 7 | 1 | 4 |
PID | Unique property identification
number. No default (Integer > 0) |
MID | Material identification number of a
MAT10 material entry. No default (Integer > 0) |
MODINT | Modified integration element
formulation option. 2
ESBYL | Number of adaptively meshed
elements to be present in the minimum wavelength of each
frequency band. Default = 4.0 (Real) |
TBYL | Ratio of the thickness of each PML
layer to the maximum wavelength of the frequency band.
Default = 1.0 (Real) |
MESHG | Maximum Ratio between element size
of a neighboring element and the size of a particular element.
This option allows you to control neighboring element sizes to prevent poor meshes for PML computations. Default = 2.0 (Real) |
MESHM | Meshing method to be chosen for
adaptive meshing.
DBNAME | Database file name which is used to
save meshes generated during the APML process. Default = pml_DB (Character) |
EPS | Regularization parameter for
distance field computation. Default = 0.001 (Real) |
XP, YP, ZP | Coordinates of the pole of the APML
acoustic elements (defined in the basic coordinate system).
Default = Center of Gravity of PML layer (Real) |
MFID | Identification number of a
MESHF Bulk Data Entry, which manually
identifies the frequency bands for adaptive mesh generation.
Default = Blank (Integer) |
NBND | Number of frequency bands in the
range of frequencies (from the minimum to maximum frequency in
the range). Default = Blank (Integer) |
BNDTYP | Scaling type to be used for
frequency bands. 5
ADAPF | Adaptive factor for generation of
frequency bands (ratio between the maximum and minimum frequency
for each band). Default = 1.2 (Real) |
- Adaptive Perfectly Matched Layer
(APML) mesh at the outer boundary of the acoustic domain ensures the
following conditions are satisfied:
- Acoustic waves at the interface do not get reflected.
- Waves which pass through this layer are attenuated.
- Direct and Modal Frequency Response Analysis are currently supported.
- The four continuation lines in
this PACPML entry allow the definition of the following
characteristics:
- Line 1 – Definition and element formulation.
- Line 2 – Adaptive APML mesh generation properties.
- Line 3 – Distance field computation (determines the complex coordinate stretch direction).
- Line 4 – Defines the frequency bands.
- The modified integration flag in MODINT may be turned on to reduce the dispersion error (which is the error in the computed wavelength, measured relative to the actual wavelength, for an acoustics solution).
- Adaptive meshing is automatically carried out either via HyperMesh or SimLab to generate the domain of the perfectly matched layer. It may be inefficient to generate a single PML mesh for the entire frequency range, as this mesh would be constrained to handle the full range of loading frequencies (from the lowest to the highest). A single mesh which handles the complete range of frequencies may lead to a very thick PML mesh layer and at the same time, a very fine mesh. Therefore, it is a good practice to divide the frequency range for mesh generation into multiple frequency bands. Likewise, it is not an efficient practice to generate one PML mesh for every single frequency of analysis.
- A single adaptive mesh is generated per frequency band.
- The regularization parameter is employed along with the pole in conjunction with the gradient of the distance field to determine the direction of the complex coordinate stretch.
- The order of priority for frequency band generation is MFID > (NBND+BNDTYP) > ADAPF. If none of them are input, then the default of ADAPF = 1.2 is applied.
- The NBND and
BNDTYP fields provide a way to determine the
frequency bands based on the following: Where:
- Number of bands (NBND)
- where
- Frequency bands
- and
- Minimum and maximum loading frequencies
Then based on the band distribution type (BNDTYP), the frequency bands are generated as:- Linear (BNDTYP=LIN) provides
equal spacing for frequency bands.
(1) - Logarithmic (BNDTYP=LOG)
provides larger spacing at higher frequencies.
(2) - Anti-logarithmic
(BNDTYP=ALOG) provides
larger spacing at lower frequencies.
(3)
- ADAPF provides
an adaptive factor which defines each frequency band as:
(4) Where, .
