PARAM, BUSHRLMT
Bulk Data Entry Issues a WARNING when the stiffness value for rotational components on the PBUSH entry exceeds the specified limit (BUSHRLMT).
Parameter | Values | Description |
BUSHRLMT | <Real Number >
0.0> Default = 1.0E+09 |
This parameter is used to issue a WARNING when the stiffness value for rotational components on the PBUSH entry exceeds the specified limit (BUSHRLMT). |
- This check is overridden when PARAM, BUSHSTIF is used to control the maximum stiffness value.
