PARAM, INTRFACE
Bulk Data Entry Generates the .interface file to verify if proper connection has been established between the Fluid and Structure meshes at the interface.
Parameter | Values | Description |
INTRFACE | <YES, NO> |
- When the fluid domain is represented by an MFLUID card, and PARAM, INTRFACE, YES is specified, OptiStruct generates the .wetel file which contains data about the wet elements resulting from MFLUID cards. The .wetel file can then be loaded into HyperMesh to visualize the locations of submerged/damp elements in the model.
