PARAM, FCACSV
Bulk Data Entry This parameter controls the output of the .cmode.csv file which contains eigenvalues, frequency, mass fraction, mapped mode ID, additional outputs for modes, and correlation between real and complex modes from Acoustic Complex Eigenvalue Analysis.
Parameter Values Description
FASTFR <YES, NO>
Defaults:
  1. The default value of this parameter when it is not defined in the input file is NO.
  2. If this parameter is input without a value, then an error is issued.
YES
The .cmode.csv file is output.
NO
The .cmode.csv file is not output.
