PARAM, NEGMASS
Bulk Data Entry Allows run to proceed with negative diagonal mass terms.
Parameter Values Description
NEGMASS <YES, NO> This parameter is used to check for negative diagonal mass.
YES
Negative diagonal mass or inertia from CONM2 is allowed.
NO (Default)
An error termination will occur if negative diagonal mass is discovered.
