PARAM, PRTNORM
Bulk Data Entry Defines the maximum number of contributions printed for each norm response under the norm response itself in the .out file for an Optimization run.
Parameter | Values | Description |
PRTNORM | <Integer > 0> Default = 10 |
The top PRTNORM number of contributions (element ID, response value, and constraint violation) for each norm response are printed, with a default of 10. |
